Root How-to Root Optimus M 2.2.1
illbandito
This tutorial will get your Stock 2.2.1 LG Optimus M Rooted
Located { HERE } at my blog.
Anyone feel free to copy it over to the forums I just got off work and im tired at the moment & do not feel like it.
I have also added all the files needed to do the root to a torrent and uploaded it on demonoid.me I will be seeding for the next 3 weeks, if you download remember it is common courtesy to seed! PLEASE SEED!
Files included
-MS690ZV4-root
-android-sdk_r10-windows
-Custom Recovery for 2.2.1 stock phones by joneidy(2)
-LG-LGNPST12
-LGUnitedMobileDriver_S497CA20_WHQL_ML_Ver_1.0
The torrent can be found { Here }
I'm obviously new to the forums & the android world. I just kinda went head on and rooted my phone right off the back ( Only had the phone for a few days and I couldnt stand the bloatware, Plus having root has lots of benefits I could not pass ) I googled for a while before ended up here trying to root my phone. The tutorials here were a little out-dated and confusing for me so I after I got through them I just wrote my own using the ones here. This is the first tutorial I have ever written and the first blog I have ever done. I have lurked the internet & more specifically tons of forums for too long and decided its time I give a little bit back.
Thanks to all of the people that have taken time on here to write similar tutorials & guides
again, the tutorial can be found HERE <-- Click it!
Feel free to notify me of any spelling corrections & errors in the tutorial. I will try to help as many people as I can in this thread but I cant promise anything.
Thanks are appreciated!
I got all the way up to where you use the cmd prompt and am completely lost now, when i type the "su" without parenthesis it tells me that "it is not a recognized as an internal or external comment,operable program or hatch file." Need help asap. thank you.
Copy Paste this
Code:
cd C:\Optimus Root\android-sdk_r10-windows\android-sdk-windows\platform-tools
your command prompt should look like this
then hit enter, then go foward with the tutorial.
Also i was looking at mikekelso's video and it showed that when he pasted the code onto the cmd it gave him back just some #'s, and with mine it runs a lot of different codes. why is that?
I really appreciate you helping me but i think i must have done something wrong because nothing on my cmd seems to work, when i put adb it says that it doesn't recognize it. same with su and all of that. also when i type adb shell, says that it doesn't recognize "adb". i'm going crazy now. lol
Thanks a lot, finally got my phone working. Only problem i had was with the adb shell commands, fixed by changing the directory to OptimusRoot instead of Optimus Root. Apparently adb shell did not like the space in the directory name.
Files included
-MS690ZV4-root
-LG-LGNPST12
I used your guide and I want to thank you for the newbee help it gave me. The only trouble I had was at the end with the "su" "busybox" and "superuser" being in the folders. I had to put them directly in the C: drive and change the cmd lines to reflect that and not list the folders. Then I was good as gold... Thanks Again!!!!:):):):):)
When I click start and put in the SPC # it will run for about 20 seconds then i get this error unable to load [LGNPTS_PortManager5.dill] Componet Path= C:LG Electronics\LGNPTS\Components 4.0\LGNPTS_port Mananger5.dill Version=HR=0x0
Disable UAC, Disable your antivirus and run LGNPST.exe as admin. Should do the trick.
Have done that with the same affect. It happens when I start LGNPTS. I was having a problem with the cdma workshop that was related to my antivirus so I have had it disabled since then.
After rechecking my UAC found it had got back on. Thanks for the reminder
Ok go into the folder located here
Do you see a application file named " adb "
I dont have an "adb" file..... I jast have a "read me file" it says "The adb tool has moved to platform-tools/
If you don't see this directory in your SDK,
launch the SDK and AVD Manager (execute the android tool)
and install "Android SDK Platform-tools"
Please also update your PATH environment variable to
include the platform-tools/ directory, so you can
execute adb from any location." not sure what this means
Never mind got it working by updating SDK Manager
