soapinmouth
So it seems alot of people are having problems getting ADB I myself included, so I used this method instead from the Droid forums.
one tip though is I used skyfire instead of the default browser because the download didn't seem to work right, and because fo that all the lines of code should have an s at the end of the word download ("download" -> "downloads")
Droid X Hacks - Droid Forum - Verizon Droid & the Motorola Droid Forum
Now that root is available for the Droid X, there is going to be a swarm of people installing the Android SDK to have access to ADB. But you don't need to do this. You can install a terminal emulator from the Android Market and root your Droid X without using a PC. We'll be using a modified version of the guide on Alldroid.org to do this. Thanks to birdman and everyone else involved! Here's how:
Get a terminal emulator and Astro
There are a few available on the Market. Any of them should work fine. I recommend Better Terminal Emulator ($1.99 I believe) but there are free options available.
Then download Astro managerThere's a free and pay version, either will work.
Download the files you need
You'll need to register on Alldroid.org to download the files. Then download the attachment (using your Droid X) in the first post of this thread:
DROID X IS ROOTED! (ADB and Shell as SU with System mounted as R/W, NO Flashing or bootloader yet) - Motorola Droid X Rooting - AllDroid Public Board - DROID X IS ROOTED! (ADB and Shell as SU with System mounted as R/W, NO Flashing or bootloader yet)
The Android browser likes to make the filename goofy, so we'll need to change it. Open Astro.
Press Menu -> More -> Preferences -> Look and Feel and make sure "Hide File Extensions" is disabled. Press back till you're at the file list again.
Open the download folder and then long press on the file "resource.ashx" and rename it to "update.zip", then long press again to extract it, and "Extact To This Directory".
Gaining temporary root access
First make sure you have a Power Control widget on your homescreen and [! important] wifi is turned on. You're going to need to access this widget very quickly after you type the following commands.
Now open your terminal app and type the following commands:
Code:
cd /sqlite_stmt_journals
cp /sdcard/download/exploid ./exploid
chmod 755 exploid
./exploid
After typing the last command, quickly press your Home button and turn wifi off and then back on with the power control widget. You'll know if you did it fast enough after you type the next command:
Code:
rootshell
If you are prompted for a password, you were fast enough. If not, type ./exploid and do the wifi thing over again. When you are prompted for a password, enter secretlol
Copy superuser files
You now have temporary root access and need to copy all of your files in to place to make it permanent. Type the following commands:
Code:
cp /sdcard/download/Superuser.apk /system/app/Superuser.apk
cp /sdcard/download/su /system/bin/su
cp /sdcard/download/busybox /system/bin/busybox
chmod 4755 /system/bin/su
chmod 4755 /system/bin/busybox
rm /system/bin/rootshell
exit
You now have root. I needed to close my terminal emulator (in Better Terminal, you need to actually click the menu button and exit) and reopen it. After this, type su
If anything other than your prompt changing from $ to #, something went wrong. Otherwise, you can start using apps that require root!
) some folks to root that otherwise would never be able to. There's a similar "phone-only" method for rooting the Eris that's been a lifeline to a lot of folks.
