When you are in gallery if you dont see an option called "All downloads" hit menu>settings>default albums then put a checkmark in all downloads. If you dont see "all downloads" in your gallery and you go into settings and its already check marked then you gotta wait for the smart people to get on.
Another option would be to download astro file manager or ES file explorer from the market. Then go into your card and find your download folder, /sdcard/download. Is it there?
What method are you using to save the image from the source?
Hi, yes it is there, but it will only let me open the images, it will not let me photo shop them, or use them as a background. (using that app)
Any other ideas?
I worked when I first got the phone, maybe I should reset the darn thing?
In the file manager app make a new folder in the root of your card and name it whatever you want. Then transfer the pictures to that folder. Then when you go to the gallery you can open that folder with the pictures.
Thanks for the idea.
But I don't want to have to deal with the extra step.
So I am going to restore my phone.
