If you have or go get a google voice account you can use that for visual voicemail. It's what I'm doing, and it works pretty well.
Not ready for Google Voice. I still have no clue how to set up basic voicemail though. Anybody know? Already tried, dialing 1, calling my own number, etc. and no luck.
A lot of times when switching phones the voicemail gets messed up and needs to be reset. What does it say when you call your voicemail?
A lot of times in the store we get the message "More information is needed to access your voicemail", which means it just needs reset.
Either stop by an AT&T store, or call Customer Care(611 from your phone), and they can reset your voicemail for you. Once done, holding down the 1 button brings you to the automated setup.
About 5 mins after reading this post I decided to just wing it and try to figure out the Google Voice voicemail on my own...
Step 3: Download the Google Voice app from the Android Market
Google voice is already on your device-it is in the applications list as "voice". If you want to use google voice as your voice mail, make sure you're signed up for google voice then go online and go to settings and activate google voice for your #
