Get a different browser from the market place. I recommend Dolphin Mini, REALLY quick.
Then go into the settings and change the 'user agent' from android/mobile to desktop. Sorted : )
Type about:useragent into the address bar in the default browser, select desktop.
It'll revert back to default with every boot.
Thanks, that sorted it. Now I need to figure out why my wifi has only 2 bars showing when I'm only sat 2m away from my routers antenna.
seems to be that the sgs2 has a weak wifi antenna
