Hey I had the same issue and went to the calendar app, pressed the menu soft key button, went to "more", then "calendars", then unchecked facebook. Then once you go back to the calendar it should remove all the facebook birthdays. Hope this helpsIn accounts and settings for facebook I only have the options for sync contacts and sync live feed - nothing for birthdays.. am i missing something? This is listed as Facebook for HTC in the accounts and sync page... there is an option to add a difference 'facebook' option instead of the HTC one, but this does nothing when i click it?
Also i have read you can go into the stock calendar app, and from there uncheck facebook which will stop the calendar showing facebook info. But suprise suprise, my phone doesnt have this option either!
