Help How to switch on led flash manually?
@Everyone - Try TestlaLED by TeslaCoil on Play Store. I've tested it on UB-1, UB-2, ROOT5. All working, has desktop widget to enable and disable LED. You can switch the flash on and use as flashlight.
[WARNING] - If you keep the flash on for more than 7-9 minutes, the LED would burn away as massive amounts of heat is produced. Please DO NOT keep it ON constantly!
