Root How to take a Screen Capture with sprint LG Marquee
Well first off you have to be rooted.. Secondly if you have CTMod from Bloodawn you can hold power button and it is an option. If not you can download a screen shot app from the Goole Play Store. I personally use Screenshot It Pro. Has nice options such as edit, draw, and crop after you take a screen shot. Though there are other options available.
Screenshot It:
Screenshot It Trial - Google Play Store
Try the app SCREEN GRABBER, in the GOOGLE PLAY STORE.
This one does not require root, at least on some phones. It's worth trying out, for one, it's free, & especially if you don't want to root just to get a screen shot.
Thanks for the info.I thought about mentioning some of the non-root SS apps, I just couldn't remember if the Marquee could take SS's without Root. I was thinking it couldn't.
I recall trying a non root version once. Doesn't work. If the app isn't set up to request root, then it will try and take a screenshot without root. I tried one like this on my phone and it failed. Root is required with this phone. :P
