How to take screenshots?
Man, I am not familiar with your device; there _might_ be an app for it, but I remember back in the old days we could use abd to take them. Of course you have to intall abd on your computer and enable "usb debugging" on your device.
Did u try the basic home + camera or the home + volume up (or down can't remember) or if u received rooted search thru custom rooms that have that feature built in
The button combination doesn't work on pre-ics devices. Its much easier to just install a custom rom that has the feature built into the power menu.
