if that's the case then my jit is not working,, by the way, i have made a backup using xrecovery before installing jit. can i just restore it and repeat jit installation?
Hi gabeyong!
I've been following ur post coz it help me a lot in my installation of xrecovery and the custom roms (you use simple and easy to follow methods). I'm wondering if you also have a tutorial on installing jit?
I think the 2.1 w/ xrecovery, link2sd and jit will be okey for me for a while until the 2.3 Rom is complete.
Thanks in advance.
