Root How to uninstall clockwork recovery mod on droidx
Kevin123
Member
yeah how do you do it? i want to get rid of it because every time on boot up the clockwork menu pops up and i have to manually click from the camera button to click start and even i unroot the phone the menu still appears on the start up so can anybody tell me how to uninstall the clockwork mod?
Thanks For you help
Kevin
Thanks For you help
Kevin
need to know a lil more about what you've done wit hyour phone? Are you running stock? moddoed stock? or a cm7 variant?
install a rom, it should stop.
your not the only one all of a sudden having this issue. its kinda weird, but we will get to the root of the problem ^_^
im having the same problem kevin with the clockwork menu , keep poping up when you powercycle dnt feel bad i cant figure it out either lol , but im sure void and the other smart people will have a answer sooner den later
also kevin what you can do to , is erase the phone and the card the root an bloatware freeze thats where i am at now with my phone with no clockwork problems, i havent put a rom on it , i just erased the sd card and the when sbf so try it if u dnt value wats on ur sd
im having this same problem
i have TWO droid-x`s
both running cm4dx GB (pretty recent)
i then booted into CWR and WIPED all data (even in advanced mount)
anyway after that i took batt out and put it back in and booted up while holding power button and volume buttons
got me to be able to flash vzw .602
i then updated to .605
i then reset to factory defaults
power off phone
power on phone and CWR STILL COMES ON!
i use the camera button to hit reboot normally or whatever it says.
there is no way in hell CWR should still be on this phone
i wiped all data in CWR and i then flashed .602...and then updated to .605....what is going on?
