How to unroot?
How to unroot the Virgin Mobile Galaxy S2 GB 28 running stock android 4.1.2, I used Odin-OC SPH-D710VMUB_GB28_1014481_Rooted_Nodata? (One-click)
For your convenience, I'll even copy and paste the easy instructions from the (Un)Root Guide :)
HOW TO RETURN PHONE TO STOCK:
In case you find it necessary to return your phone to a retail store or send it back to Virgin Mobile, this will turn your phone back into COMPLETE STOCK JELLYEAN (Build GB28).
1. Go to http://www.sxtpdevelopers.com/showthread.php?t=190
2. You have two download options:
No Data Restore (RESETS user data)
Full Restore (KEEPS user data
3. After selecting your download, Double-click on the self-extractor file (.exe file), specify the directory to extract to (instructions assume C:\)
4. Start the Odin One-Click. This will be in the newly created Odin-OC folder and have the same name as the file you downloaded.
5. Place phone in download mode by pressing Volume Down + Power. Hold until confirmation screen appears. Confirm by pressing Volume +.
6. Connect USB cable to PC if not already connected. Odin should show Yellow COM port in second column. If you do not see a yellow COM port, you may need to run the ODIN One-Click as Administrator and/or unplug/plugin the USB cable after starting ODIN One-Click.
7. Start the Odin flash process by selecting START.
8. When complete, phone will automatically reboot
Status should change to green PASS!
