GiuseppeSM
Hello everybody, I have a question about app developing...
Is it possible to use a secondary APN just for a specific Android Application and let the current APN to be used by the other applications (simultaneously) ?
If yes, how?
I would be grateful if you could write a code example to set that seconday APN without to change the current one. Thank you.
If yes, how?
