KingdomMan3
I am getting sent a new Droid X tomorrow but of course I have to send my old one in. I am flipping between custom roms but also would like to know how to virginize it so everything looks stock.
and do a factory reset before you sbf.
No, it doesn't have to be done before. After is fine. The SBF simply wipes the system partition so you just have to factory reset at some point either before or after to delete user data.
Sometimes it's easier before because, if you have user data or cache that somehow prevents the phone from booting or throws it into a boot loop, you don't have to coordinate the battery pull/holding home to boot into recovery. That's the only good reason to do it before, though.
