Help How would I debrand to get ICS?
slugger09
At the moment I am on an Orange UK ROM which probably won't get tomorrows ICS update, how would I debrand the phone to be able to receive these stock updates?
You can't, as your device will be ID'd as an Orange handset no matter what firmware is installed so only their firmware will be offered.
There will be Odin-flashable packages available soon after 4.0.x starts rolling out, which (if they themselves are unbranded) will let you kill both birds with the same stone. :)
I flashed stock UK firmware and it worked OK, and updated to 2.3.4
