Better is relative ;-) is it a good phone? Yes. Is it worth it? Thats up to you. Its a slightly smaller screen, but its bright and has lte capabilities
Edit...
To add to what i said earlier. Do you like custom roms and such? There really arent any for this device at the time. So that may or may not be a factor.
Because honestly, I can get an evo v for $130 new, whereas the Victory is 229, my cost
I just upgraded to this from the Evo V. The only thing I really miss is CM10.1. The smaller screen doesn't bother me like I thought it would. Battery life is better on the Victory and LTE is awesome. If you don't have LTE I would probably just get the Evo.
Speaking of problems, I've read in another thread here that someone had activation issues when swapping phones. Did any of you guys have the same problem? I have a friend that wants to upgrade from the One V (mainly due to the LTE which is available here and the overall smoothness of this phone), but she uses her phone on a daily basis, so it's important that the phone swap goes without any problems.
Yeah, it took them..approximately 6-8 hours for it. Then once the phone is ready, it does indeed reset itself back to factory defaults. Other than that...that's the only 'issue' I had. I took a nap and cleaned while I waited![]()
