My phone keeps restarting from the htc quietly brilliant screen to the at&t screen over and over again. I am scared that it is infected by a virus. What should I do?
Are you rooted or stock? If stock, pull the battery then replace. Then press and hold volume down while simultaneously pressing the power button. Did this bring up your hboot screen? If so, try a factory reset from this location. (Volume buttons to scroll, power button to select)
Hope this isn't considered a hijack but I have the same issue.
I have a rooted Aria and have stable/gingerbread/update-cm-7.1.0-Liberty-signed.zip on my phone. It started to reboot after I took some updates from the Android Marketplace. I don't know which update is causing it, if any.
I put on RC/update-cm-7.2.0-RC1-liberty-signed.zip and the rebooting went away for about a week and now has started up again. There may be some automatic updates that I have set up and I believe this is the major problem. Is there a program out there that I can us to determine the newest updates, chronically?
