Just wanted to say I am having the same problem with my HTC Desire on 3. The default browser seems to get stuck quite often and does not load web pages. I have a 3g connection and other programs have no problem downloading /accessing the internet i.e. marker, opera mini, email etc..
...and having popped out the battery, put it back in and switched the phone back on, I immediately got a HSDPA connection.
I also do have 3G Watchdog installed, I wonder if that could be related? I did notice that with the last update the setting for showing the icon only when 3G is active no longer works, and the problems seem to have started at around the time I installed the last update. If the problems persist I'll uninstall it to see if that helps.
Sorry to hear you have a problem, but to be clear I don't think this is actually the same problem I have experienced. I either get data access for all programs or not at all - I don't see any icon for data access when the problem strikes, be it G, 3G or H (never seen 'E' on the Desire, does it have Edge?).
The only sure way (touch wood) so far I've found to get access back is to pop out the battery and restart the phone, at which point the phone has always (so far) connected correctly straight away.
Hmm might be a couple of different issues going on here. My issue with intermittent problems with data connections seems to be linked to the default browser.
Hi,
Point taken - I have started a separate thread.
Hi !
Same "no data at all" after switching off my wifi on Orange CH on my Desire.
I have a workaround, much faster than rebooting the Desire : turn on the Plane mode, then off, you have to put your SIM code, then the data is back...
Hope they will fix this, cause when you're not looking at it, no push to mail is working...
Seems to be Android related...
My Deire stopped data over the weekend, and after checking under settings, it had changed itself (yes itself) to WCDMA ONLY. I had voice, but no data.
Set back to auto, and have both 3G and HSPDA data again.
Very odd.
Reading the T-mob forum in a bit more detail I came across the following link, looks like my issue could be a problem with Android.
Issue 2207 - android - Net access fails after leaving WiFi - Project Hosting on Google Code
I've had my Desire for a couple of weeks now, but am experiencing some problems. The main problem is that I'm not always able to access mobile Internet even when there is coverage. When this happens I just can't get onto the net at all (no symbol for 3g etc) even if I try to switch off and on the mobile Internet.
The only solution I've found when this happens is to reboot the phone, once rebooted I get 3g access. Which brings me to the second problem, in that trying to switch off the phone it just hangs and I eventually have to take out the battery to be able to restart the phone.
Has anyone else experienced similar problems, or is my phone perhaps faulty?
I too have un-branded Desire with Orange card in it.I can connect to the internet but I never get 3G icon lit up.Does this mean I am not connected to 3G network?and only cennected to slower G network? I have tried to set the phone for WCDMA only but the phone reboots and auto selects GSM/WCDMA option.
which as you can imagine is a tad limitiing for general web browsing let alone using the sat nav etc.
so a big f...... mess.
