P panpanpan Lurker Jan 15, 2012 #52 Rastaman-FB said: its saying bad as the download is corrupt btw thats the data to ext version so if you havent set up your partitions right you may find its not performing as you want use the a2sd version Click to expand... I want to flash MIUI xj and have read through many posts but don't quite understand the difference between A2SD version and D2EXT X-PARTED version. I have partitioned my SD card (1 gb for EXT3) and would like to save lots of space in my phone as much as possible as I have loads of games. Can you recommend me which version would be suitable for me Thanks
