emilronnow
Member
error 25011
Model: Windows 7 Extreme Edition R1 PCWhat OS is your PC?
Processer: AMD Athlon Dual-Core QL-60 1.90 GHz
System type: 32-bit Operating System
Do you mean that? - Im not in to computer ;-)
So i have to burn something stuff over til a normal cd? and then put in the pc and.... i guess i have to find a guidelol windows 7 extreme edition, its not a legit copy of windows and half the netframework will be out of date.
anyway the alternative is to make a bootable cd from the gparted website and boot to it
look in our root stickySo i have to burn something stuff over til a normal cd? and then put in the pc and.... i guess i have to find a guide![]()
Okay - thank youlook in our root sticky
there is a video tutorial
a2sdOkay - thank you
Which ROM do I have to be on now when I want to enable a2sd?
Im want to end up on the MIUI XJ ROM above....
Im not sure I understand....a2sd
if you look on the list of roms for miui xj, the same place you downloaded the d2ext one. you will notice one that says a2sd in itIm not sure I understand....
a2sd that isnt a ROM is it?
Or do you mean it have to support a2sd?
and if, which one support it?
But I still have to partition my sd-card with burning gparted to a cd, and then follow the guide?if you look on the list of roms for miui xj, the same place you downloaded the d2ext one. you will notice one that says a2sd in it
Okay, thanks - Where is your guide, I cant finde itno. and follow my guides.
Now I have burned gpated to a cd....In the "all about rooting" sticky thread, or in my signature (Shows once per page)
isnt it the one I wrote above?Use the video or guide linked at the end of my VMWare virtual machine for gparted guide
