For metrodroid you don't need any scripts. I have never used it so I can not tell you if it works but it says it works out of the box. I'm running Deck's Reloaded and I flashed MMS fix for AOSP and it works perfectly. I have also used MikGrom and sense 3.5 roms with no problems after flashing script
