John Redcorn
On the stock rom there was a feature called fast boot that; if I'm correct in my assumption, worked probably somewhat like windows hibernate and just saved ram to disk.
I don't use the stock rom and probably never will use a sense rom, if I'm right about how that works, is there a separate 768mb partition it used? A partition that's probably doing nothing now? Can /data be expanded into that space?
