HTC Inspire 4G Screen and Antenna Cables
Maichael
Ho to all;I am buying the HTC Inspire 4G cellular with a bad screen and i am buying the all parts and i did the installation but now i have a lot of bubbles between the LCD Screen and the Touch Screen Digitizer.I remove both parts and i clean the all parts but when i did the installation if i press just a little bit the screen i got the bunch of bubbles again!!!
And i need to know the correct antenna wire connectors near the battery.It is because i am buying this cellular with the all parts removed but in this location i have two plugs but i need to know the correct location for the White and Black wires.I know the correct locations of this cables because the White cable goes to the top left corner and the black is near the speaker and Many Thanks Anticipated for any help.
I would make a reply on the link that iowabowtech posted, as the OP was able to solve my problem when asked about the parts I would require to repair my unit.
