David Aames
I have a htc m8 "stuck",
im new at this so first i load the recovery (twrp-2.7.0.2-m8.img) format everything and try to install several the roms... none of them work (MARSHMELLOW, VIPER ETC), then i flash a new recovery (twrp-3.0.0-1-m8) and try to install the rom (Android_Revolution_HD-One_M8_53.1_c8bf38) and nothing just boots right to the bootloader...
right now this is the status:
the m8 has bootloader unlocked and is sf off
i have the fastboot and drivers
have the original htc usb cable
pc DOES recognice the device in bootloader
also have squabbis and hassoo2000 tool kits
hope someone can help
regards!!
regards!!
), in which case you will need to use Verizon-specific versions of the ROMs and probably also a recovery built for that model too. If you were using code for the non-Verizon M8 that is quite possibly what's wrong - generally VZW HTC devices need their own version.
