Accessories HTC Mains Charger
Hi everyone
Does anyone else have a problem with charging their phone up? Everytime I order a new charger, it lasts me four days or a week until it stops working, and then I have to buy a new one.
Is it obviously a phone fault? The chargers are all original HTC.. Its really annoying me now..
thanks
Yeah, I presume it's an issue with the phone as opposed to the chargers.
Have you tried blasting the charging port with a can of compressed air? Does the phone charge fine over USB?
Nope, i haven't tried that.. I'll give it a shot.
I've tried charging over a usb port.. Still the same!
I hope I don't have to send it off, HTC will wipe all my stuff..
Are you sure it's not the socket which is blowing them? Tried other sockets in the house?
I'm not sure how you would go about testing a wall socket though. If it doesn't blow in the usual time frame when using a different one then there must be a problem somewhere, I doubt it would be an issue in your whole house though otherwise your tv etc would go.
I use a Blackberry charger in the work and there is a Samsung Galaxy S charger behind the bar in my local in case of battery emergencys, both of them are a far better fit than my original HTC charger that i use in the house.
Does yours charge alright from a blackberry charger? I've used one a couple of times and it takes about 3 times as long to charge.
I also use a blackberry charger, which charges fine for me but it doesn't go all the way in so if I pick my phone up while its charging it just falls out, gets rather frustrating after a while
Thats exactly the problem i have mate with the HTC charger, bizarre.
Can you guys please post links to the websites where you have bought your chargers? I need one that charges with the full 1000mA and not the 500mA as in USB mode.
Better in what way?
