Hello,
I have a HTC MyTouch 3G (Not Slide) phone which is having problem with the Bluetooth feature, it doesn't turn on. I've read around the web of people having a similar issue and in most cases it has been identified as a hardware problem but I just found something strange with the problem I'm having.
When I try to turn on the Bluetooth option under Settings -> Wireless & Network -> Bluetooth, It's always OFF and when I press to turn it on, it stays on "Turning On" for a few seconds and then does nothing, it just stays OFF.
I was looking around under Settings -> Applications -> Manage Application -> Running, and I see the Bluetooth Share App is running and to see if I could troubleshoot the App, I decided to turn it OFF but going in the App and Pressing "Force Stop" and then the odd thing happened, I lost my Service Signal, it just kicked me out of the network and it took about 30 seconds for my phone to reconnect to the network again.
I thought it was odd so I tried to stop the "Bluetooth Share" app again and it disconnected the phone again and again and again.
I want to reinstall the Bluetooth app but I can't find the .apk and .obex files anywhere to download them. My phone is currently rooted and I wouldn't have a problem doing it.
I'd like to know if anyone has experienced a similar problem and also if it's possible to reinstall the Bluetooth app.
My phone is running Android 2.3
Thank you
Thank you
