Root Huawei Ascend G510-0200 issue. Can't flash, can't wipe or ahything...
I got huawei G510-0200 from friend to try to fix it. The phone is allready rooted and has installed a custom ROM(SlimKat 4.4) and TWRP recovery. But when the software is booted up, all the time i get the pop up message of applications crashing(play store, messenger, nova launcher etc) and i didn't run any application. So here's the real problem... When i access recovery and try the full wipe, factory reset or installing new rom, twrp reports that actions are successful but nothing happened. Nothing has changed. The phone was not reseted, data and applications are still there and same rom is still running. It's also same when i try to install new kernel or recovery. I also tried with stock flash(vol+, vol-, power button) and i get emmc is readonly, you can't update your system. And also tried using adb shell and terminal while phone is in fastboot mode, and i get the same results. Adb can't flash and using wipe it can't wipe cache, system and data partitions, i get the message "command not allowed".
Anyone had this problem, any ideas how to solve it?
Thanks in advance...
Welcome to our AndroidForums, evilg3nius.
Just want to let you know I've moved your thread over to the all-things-root sub-forum for you since the folks in here should be able to help you best.
Best of luck!
