I rooted my ascend and accidentally deleted google talk and that messed up my market downloading abilities. Here's what I did to fix it...
Step 1:
Download, Extract, and Transfer the contents of this zipped folder to your phone. You can simply do this by plugging your phone in via usb, and dropping the rootexplorer.apk into your download folder.
Link:
http://dl.dropbox.com/u/1239859/Root%20Explorer.zip
Then, go into file manager, Tap the SD Card Tab, go to download folder, and install the root explorer.apk
Step 2 : Download, Extract, and Transfer the contents of this zipped folder to the same download folder.
Link:
http://dl.dropbox.com/u/1239859/Talk%20App%20and%20Services.zip
Step 3: Go into root explorer, navigate to your SD card, then to the download folder where you will find the following files
1 gtalkservice.apk
2 talk.apk
3 talkprovider.apk
These are the 3 you just transferred over.
step 4: Long press on one of those, and click copy or move. Once you click copy, you will see your next option on screen is to paste. Click back 2 times, and scroll to the bottom and you will see system, click system, then click apps. Paste that into apps. Then go back to the download folder again inside your sd card, and do the same for the remaining two files. Once all 3 are moved or copied into the /system/app folder, reboot your phone, and try to download something, if you get the force close error still, then do a hard reset.
