Help huawei ascend y330
steve h
Can anybody tell me how to get the GPS for the ascend y330.found it once by chance but cant find it now.many thanks.
this can be a problem could not find an answer anywhere i found solution was to remove SD card restart phone and insert SD card in phone while it is powered on. my card was then accepted by phone hope it helps someone out there this worked for me after trying for hours to get card to work .:rolleyes:
Hi Steve, I just bought a Y330, and I had trouble getting a Sat-Nav app running. I am not an android expert, but I guessed that the problem was the clock on the device (not the time and date showing on the home screen, but the actual clock used by the CPU). If I tapped the "determining location" button, it showed the clock set to 1/1/1970. What I did was download a GPS app, I used this one, https://play.google.com/store/apps/details?id=com.chartcross.gpstest&hl=en_GB. Switched on GPS and WiFi, and left the phone outdoors for a while. Now it works very well indeed.
OTOH, if you were asking simply how to switch the GPS on, then pull down the top bar, you should see a line of icons representing, WiFi, Mobile Data, Auto-Rotate, Bluetooth and GPS. Tap the one you want to toggle on/off. HTH
Y330 does not have magnetic compass. It Does have GPS.
some apps will not work if they require compass ..... Eg find the ISS in the sky.?
