Root HULU flash help
jackdubl
Android Expert
Have tried to get HULU working but I can't really follow the instructions. So I tried the flash method but the files don't seem to load. Verified busybox is installed. Then I tried to just install the apk and now I get audio to play but not video. Can anyone help?
Well, I got some crappy 4 minute news clip to play fine, but everything else I just get the audio and a black picture for the video. I guess I'll give up on this as I've spent about 5 straight hours trying to get it to work. Tried every method with the same results. I can maybe get a short clip to play off the home screen ok, but everything else is just audio with no video. If anyone has any solutions i'd love to here 'em.
I'm not sure how to help. I downloaded the one with flash 10.2 and I'm using droidtheory's shift aosp rom. I emailed the apk I used to my friend who has a T-Mobile g2x and he says its not working for him.
I am using shift 1.2. All you did was use the 10.2 apk with no other steps. Didn't do anything with the. so file? I guess I could try tomorrow. What the hey.
The first one is the only one that works for me. None of the rest do. Funny, I gave up on it before I tried it. Thanks for the help.
Are any of these post related to the hulu app you get with the CM7 ROM ? I just rooted my evo 4g; and applied this rom. When I try to watch a hulu video it tells me to update my flash player to 10.3. It downloads; but during installation I get a message saying "package file was not signed correctly". I'm sorry if you guys explained how to fix this already. I'm just new to all of this.
Not sure about for your phone but I know CM7 on the bolt works better with 10.2 not 10.3, might want to see if you can get a copy of the apk to sideload then uninstall the 10.3 and install the 10.2
