Help i did it with no issues
1iwilly
ok i took the plunge to modified my phone recovery worked with no issues install the oc kernel=r.O.C.K-v0.3-AnyROM no issues i also install battery calibration that was listed to use with this oc kernel i set the cpu at max-729 min-245 phone has no issues even under the stress test i still have the check mark off on set on boot now the question is been that there is no issues do i now put the check mark to set on boot??? also do i add a profile.??? if so what would be the correct settings ?? i do notice the phone to load app faster at that setting.
You can raise the number 729 by incriments to see where it no longer works then set it one setting lower. when you found its stable spot you can check the box to set on boot.
You dont need a profile, though if you want to you can. some people put lower cpu while screen off, so it conserves battery. but the little bit that is conserved isnt worth much in my opinion.
