Help i give up!
EVO-DROID
Member
So I bought my wife an evo, she loves mine so I got her one. I never had issues with mine as far as the battery. Hers on the other hand is horrible, within an hour and a half her phone was down to 45%. With about 10mins phone use and 15mins internet use at max. I have followed all of the guides to get the most of the battery. help/advice?
Download the app Spare Parts and System Panel. In spare parts, go to Batteyr History, then click Partial Wake Usage, this will tell you whats running when it shouldnt be. You can also use system panel to see how much cpu time each app is using.
yup...most likely she has a rogue app that is keeping the phone "awake"
The battery that originally came with my evo last half as long my replacement sprint gave me, did the same initial charge and calibration techniques on both, and defective battery is definitely possible.
Quick system info has same usage data and much more check it out
