I have a question....
Steven58
Former Heavyweight Champion of Android Forums
Moderator
Why is there a link to the irc channel using a java plugin that hasn't worked in about two years? Just asking. Was curious. My thoughts? Either get it to work or dump it.
(Steven slinks back into obscurity). :p
Well ...
The Java applet still works.
And there are still people in the channel (although I suspect it's been a while since anyone said anything).
So you got your #1 choice - it works.
Well it neither works for me at home or at work. I am using Chrome and IE at home and work and it simply doesn't work. I get the following message:
Startup error: java lang error: Unable to load interface pixx: comsun.deploy.security.BlockedException: Your security
Hmmm... do you think Norton is blocking this for me even though I enable the applet?
Some of the latest java updates have included extra security protections and has broken a lot of applets that use it. The error you're getting seems to be indicating that you either denied it access or the security upgrade is being enforced.
I ASSUME this is the Chat Live link ... correct?
When I selected it under Internet Explorer it gave me a dialog box and recommended that I install the latest security update. I did. The chat window then opened.
... and that's as far as I am allowed to go. If I reload the page it gives me the same dialog box and I get the same result.
... Thom
these are the errors that I receive in sequential order(ignoring and allowing the security warnings):
attachment.php
attachment.php
attachment.php
same errors on latest version of Chrome, IE, and Firefox
