Danielson2047
Nice Mr. Chaffin. We need a "No Thanks" button.
Like PARick, I have a few questions on where to really go from here. SuperUser is correctly loaded, but I need help correctly operating ROMManager(premium) and setcpu.
I DL ROM Manager(premium) from appbrain as well as set cpu. But I heard you need to have specific kernels to safely overclock the phone. I instantly created a backup so I can feel free to play around from here. Late last night I in installed CyanogenMod but decided to go back to my backup after i was unable to sync my gmail and facebook accounts using CMG.
My question to you guys, is what ROM/Kernel should I DL to allow me successful overclocking as well as that WOW factor to make me feel like I truly made the right choice.
Thanks to everyone for all their help in here.
)...you can do lots of things.
. You can delete things you shouldn't delete, you can create a lot of work for yourself fixing mistakes you make. It's okay...we all have been there...but you need to understand a few things before you move forward.
. My phone can be clocked to 1.2GHz but it's not usually 100% stable. 1.1GHz is 100% stable for me so that is usually what I run. OC'ing also = decreased battery life and increased cpu & battery temperatures. I'm running at 1.0GHz right now cause that's all I need and that extra 100Mhz could cost me 30 minutes of battery life...with no real gain. You should definitely play around to see what your phone can handle. loading a 1.3GHz kernel won't hurt your phone...it just probably won't run (or you'll see random reboots, force closes everywhere, etc.). What UBRocked said...
I was staring at your user picture trying to figure out the difference. Took my a bit to see it. Hilarious!![]()
I'm surprised no one ever mentions AdFree Android of one the first things to download from the market after rooting. For me it was worth it to root just to get rid of all the ads
may the crabs of a thousand hookers infest your crotch with while your hands are bound behind your back .... you sir ... are a jagoffHow silly.
Something useful like this post.
You know know nothing of the sort, which is why I brought it up. I don't think he knows either - just that it's something "cool" to do.
Clearly if he knew then he wouldn't be asking -- that's my point. And that too is the purpose of "these" forums.
I'll refer you to your own advice in your last sentence above.
I have read that people should do a "wipe" of their phone prior to rooting. Is this true and can someone maybe explain how to go about doing that and what it exactly removes from your phone (ie photos, videos that are saved on your memory card).
I really would like to try and root mainly because I like the idea of being able to customize my phone and the wireless tether would be great also
Thanks for the help...I'm trying to get up the courage to finally root. This thread has really helped with this.
1) Reboot into recovery (ClockworkMod Preferably)
NOTE: If you haven't already done a backup...do one now. I always perform my backups via ROM Manager so I can properly label my backups. If you need to do a backup at this point it will work exactly the same way but it names your backup with time and date information (you can rename the file later)
Here's how to create a backup in ClockworkMod Recovery
From the main recovery screen, go to: Nandroid and then select "Backup"
2) Select "wipe data/factory reset" - This will actually format your Data, Cache, and SD-ext partitions
3) Go into the "partitions menu"
4) Format "Boot"
5) Format "System"
6) Go back to the main screen (power button backs you out to the previous menu)
7) Install zip from sdcard
8) Choose zip from sdcard
9) navigate to where you have stored the zip file and select it (no need to rename the file)
NOTE: You can do the same thing if you are using SPRecovery (you will need to rename the file to update.zip) but you have to format partitions using ADB shell (there are no menu options to format partitions like there is with ClockworkMod).
