Root I have some questions
Shadow1001
1. I rooted my Evo 4G and flashed the MIUI ROM, so I was wondering how to get back to the stock ROM?
I have Rom Manager and I don't really know how to use it
2. Can someone explain to me what ClockworkMod is and its use.
3. I wanted to free space on my SD card so I used MIUI's File Explorer and deleted all "Miscellaneous" files that took about 4GB of the SD card. It turns out, some of the files were my backup for the stock EVO ROM. My question is, do I get all the files back if I revert to Stock EVO stock ROM?
1.do not use rom manager. it tends to be very buggy and causes more issues then it is worth.
2.clockwork mod is your recovery. i would recommend that you switch recoveries to amon ra. most of the current clockwork mod's you can't flash certain zip files which amon ra can. plus aomon ra is just a much better recovery and wipes better.
3.the best way to get back to the stock rom is to just flash the rom. personally the stokc rooted roms aren't all that. i would just flash a different rom. try mikg2.5. it is the best rom out and it has sense 2.1 and sense 3.0 in it. it is very stock but has all of the features that the stock evo will never get. go to the rom/kernel sticky at the top of this forum to get it.
