I is back to android Imessages stuck between
The above suggestions won't work; I just went through this same PITA garbage.....you have to ask the sender to toggle iMessage off then text you , then toggle iMessage back on. Fixed.
* I had switched off iMessage on my iphone and called Apple to de-register my imessage from my account but neither of those worked you HAVE to do what I describe above.
Upvote 0
BEST TECH IN 2023
Smartphones
