I just bought this battery
Wow. 3600?! All Ive been hearing about was the 3000 one. I'm thinking about getting the 1700mAh. I don't really have a problem w/ the original 1500mAh, but w/o Juice Defender, this battery sucks!! Idk if whether to get 1700, or 3000mAh :/ If it wasn't for the bulk, I would happily get the 3000mAh one, no question!
The 3000 is well worthy. As the time passes you wont even notice the bulky part of the phone. ;)
I have a question does that battery TC posted cover the MetroPCS LG MS910 Esteem Extended Battery back cover perfectly?
you can find some 3500 for $10 on ebay and yes its worth it. even with the bulk. you'll say "it was worth it" =]
hii to all,
i bought a battery from ebay and it claimed it had 3000 mAH but when i actually used it i came to know it was not even 1500 mAH:mad:
but then i bought a battery from Ontrion and trust me they are high quality battery tried and tested. i just had to charge my fone for 2-3 hours and then simply forget about my charger
OnTrion Extended Battery with Door For LG Esteem MS910
try it out and you will thank me for it.:)
i have been using the exact same one in the OP for a few months now & it's working great! getting 2 days w/light, minimal use & full day w/ very heavy use!
