My phone won't let me install new app s bcoz it says low on storage space.i erased a bunch of stuff and still same message.my as card has tons more space as I just erases a700mb video.please help
You definitely need to start moving stuff to your SD card, or start installing them to your sd using an app called apps2SD or something, or wait for 2.2 when this will be possible to do without any apps
Overall, the best solution is to uninstall apps you don't use.
Yes! And make sure each app you download doesn't have auto update checked. Some of the updates take up a ton of space.
I go to applications, all, and uninstall the market from time to time as well. It defaults back to the original but saves on storage space.
And like Joser said...get rid of apps you don't use. Just be careful not to uninstall anything you need (if you are rooted).
You are correct when you say updates take up more space but, thats only for system updates. Updates to apps obtained from the market (or elsewhere) replace the old version. Also, updates to system app updates will replace the already updated apk.
In most cases you are right. But in the case of The Market that's a different story.
I want to control my updates...not the application. Thanks for the info!
Since you are rooted, you can actually replace the system version with the update.
What do you think is the advantage of doing that?
I'm curious to hear your reasoning behind this.
we should add into the sticky for people to include their carrier when they post their question to avoid always asking people who their carrier is.
That's really a great idea, NY. Actually it would be nice if they set up their profile so you could see what device they have and the carrier as well as if it is rooted, etc. Kinda like mine and yours.
Foltz, do you have Cricket or MetroPCS? Sorry if you have already answered that somewhere else. It isn't on your profile and I can't recall who everyone here is with all the time.
MetroPOS aka MetroPCS. Carrier shouldn't matter though.
It could matter because I have seen posts where users had removed the stock market and were having probs.
But that isn't why I don't want to remove mine. I see no reason to remove it. When I get updates by going to the market, etc., sooner or later my apps don't want to d/ld because the market 'data' is too big. Then I have to uninstall it and it defaults back to my original Market.
This is the only way I know to quickly clear my data from the Market.
