Root I need help flashing mikg3.1!!!
Patri
I have just rooted my phone with the help of ocnbrze but know i need to flash the mikg3.1 room. Please help!!!
here is the rom you want:
http://themikmik.com/showthread.php?10338-MikG-v3-0-12-17-2011
this is from the http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html.
hit the show button
this is all good, but how do i flash a rom or kernel?
good point so here is what you do to flash a rom:
1.first you need the vr superwipe:ZZZVR_SUPERWIPE.zip. download it and put it on your card. (optional)*
2.download the rom of your choice and transfer it to your card.
3.go into recovery
4.make a nandroid backup
5.select wipe from the main menu and wipe dalvik cache, cache, and data
6.select install (or flash depending on which recovery you have) zip from sdcard
7.find the superwipe file and flash it.(optional)
8.find your rom and flash it.
9.reboot.
first boot will take a bit longer then normal, so be patient.​
*the vr superwipe is an optional step, but i would recommend that you use it. it wipes system, cache, and boot. it wipes those three times. then it wipes the temp files and does that three times. i would not only use this tool to wipe. it should be done in addition to wiping data, dalvik cache and cache. one last thing about superwipe, this will only work with those that have support for amend scripting. only clockwork mod 2.6, amon ra 2.3, and trwp will work. so if you have clockwrok mod 3 and higher you might want to switch recoveries.​
In addition to OCN's info...
You basically want to WIPE everything except for your SD card in recovery 2-3 times and then flash Superwipe followed by flashing MikG.
(this includes wiping SD-android.secure and SD-EXT)
