i overclocked it to 748 mhz and its laggy and i cant get it to normal because it freezes half way and turns off and back on for some reason i cant get to the recovery menu
seems like your ascend is a lazy one that can not handle 748 mhz, but some are different, like mine is capable with that speed, also download this app called "cpu master" then change it through there
hoped i helped
this happen to me as well. funny thing is i kept trying to access Cyanogen settings but it kept rebooting, after like 8 boots, i finally was able to access it before it booted again & change settings also i was in the middle of downloading apps when i change settings. i thought i had to reflash back to 2.1 & start all over again but i guess i was persistant...
power off (pull battery if necessary) press SEND, VOL UP, POWER, this will boot you into CWM. Then do a factory reset/wipe data, wipe cache, then try rebooting.
Note: Never set at boot until you have tried a setting out and know it works
