ok so here is the deal.....whenever you flash something, the file you used is no longer needed....so it is not necessary to keep it on the card. it is up to you if you want to delete it or not. however, like mikey suggests you might want to keep it on the card if you have the room that way should something go wrong you can always re-flash the rom and not worry about transferring the file back to the card.
also another good thing that mikey suggests and that is to keep your nandroid backup on your card. this is also sort of the same reason as the .zip file. if there was something to go wrong you can always nandroid restore back. just remember that nandroid backups are your friend and they have saved me many times over.
and by the way, CONGRATS!!! on flashing your first rom and for getting your phone activated.
one last thing, now that you are activated, its time to do some reading. please read this guide:http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html just skip the rooting process and head on over to the after root section. there is tons of info there that you should know.......i would highly recommend that you take the time to read it.
also please feel free to ask questions here if you like.
