Root i need some help
inline6power
how do i look inside my current rom to see if anything is out of wack with my framework? mms stoped working for some reason. i cannot send or recieve mms or video. if i wipe and clear cache and reinstall the rom it will work just fine but when i titanium backup all my apps and system data, thats when i lose the ability to send pics or recieve them. i have not deleted anything from the system but it seems as something has gone missing. any help is greatly appreciated . i am running second wave with latest radio.
What were you running before the install?
rooted with stock 2.1 i have been running the second wave for a week and everythign has worked flawlessly and problem free untill today. wont let me send or recieve any pics. i also cant seem to find anything in my system/lib folder that says anythign about mms. i think some files may have went missing but dont know which ones. if i reflash the rom WITHOUT restoring my apps + data, i can send messages with pics. as soon as i back up my apps and data, cant send anymore. i have tried restore apps + system data, apps + data, and have done a couple of nan restores. nothing seems to work and i have no clue where to look to see what files may be missing.
I think you answered your own question. DON'T restore your apps and settings.
Wipe clean and reinstall from scratch.
what backup program did you use? most will allow you to install one app at a time so you can verify which ones are working. my guess is you have one app that is messing with your sms that needs to be uninstalled or not installed to begin with.
i have only used titanium backup and nandroid
One thing you can do in Titanium if you're want to keep the majority of settings/data but are having specific problems with a certain app is to Restore all apps w/ data, then on the next screen, select the app only dot, then deselect all, then reselect only the problem app...just guessing Messages 1.0 in this case? Then restore it as app only, without data.
Then you can restore all apps w/data once again, this time including app + data BUT deselecting only the problem app so it doesn't include it in the batch restore.
thanks for your help bud. this actually worked. finally lol. thanks a ton and love the name. i got a destroyer 340 and a 08 guardian. love it.
