Root I need some help!!!
Buckster
I just bought my first android phone off a guy on ebay. I haven't received it yet but one of the reasons I bought it was because it was already rooted. I asked the guy to send me info on the root so I know all the functions but basically all he knew was how to start the phone normally. He had a friend at a cell phone shop install the root for him. I know it is "fission 2.5.6be". Can someone give me a website to look at or send me some basic instructions? I should be receiving the phone in the next couple days and I wanna know all about it before I get it activated.
Thanks!!!
Well, as far as I know all 'roots' are the same. In other words the process on how to root the phone doesn't matter because the end result is the exact same. A phone is either rooted or not, and whether it was done by the Z4 app, or fission doesn't much matter.
After the root, it opens up a lot of options for the phone. Check out some of the threads that are floating around on the advantages of rooting.
Thanks!!!
here is some basic reading info
http://androidforums.com/droid-x-al...ide-root-unroot-backup-rom-sbf-overclock.html
If the phone is running fission 2.5.6be it has been more than rooted. A new ROM has been installed on it. That means over the air updates and such will likely not work unless the ROM is changed. This is not as difficult a process as it sounds and there is a ton of reading on this site that can point you in the right directions.
