i robot ;)
dan55
Android Expert
Hi guys
Well I made the leep and now have a lovely new
Desire in my hands :)
Shall keep you posted about my thoughts as I
Make the move from iPhone to Android :D
Cheers
Dan
the internet looks a bit shocking! not as good as me old ip 3g :(
have i got it setup wrong ?
ta
Welcome to Android Forums first and foremost!
Secondly, a vast number of people use the Dolphin HD browser instead of the stock browser. I didn't mind the stock browser but the Dolphin one is much better IMO (especially due to the full screen mode). Also, Mozilla Firefox for Android is in the Beta stages and looks to be a future "winner" after some more tweaks.
:D hi guys -thanks for the info and the welcome - in particular this site seems to display poorly - ie the font is very small from the start and so you have to zoom in a lot to read it - another forum i was on was better after i posted
probably new phone panic! :D
cheers
dan
ps: will check out that other browser - thanks
cheers
dan
if you like to visit forums... there is a great app for that.. but sadly it dont work for this forum!!!
try: Tapatalk
from high....to low - cant get all my yahoo mail folders - pim not as good on android - phone not that fast- odd functionality in places - sob - where did i leave my iphone :( :D
gonna have to work at this one i feel
Dan, on most of the different browsers including stock when first opened they are in an overview. Really annoying if you ask me. If you go to setting in your browser options untick "open in overview". Also from the settings menu you can choose your user agent (ie android or desktop).
Thanks guys. On a plus have just syncd calendar through my
Pim, internal calendar and Google :)
If you fiddle with the settings for the default browser you should be able to get the pages to display as you want them. You can set the default zoom level.
The standard HTC mail app won't display your yahoo folders and is generally carp anyway. The Desire obviously works best with google mail.
To display your yahoo folders you can use the yahoo app suggested above or other decent mail apps on the market such as k9 or maildroid.
thanks for that - changed the overview setting and now text is more readable but page is very wide - will try it and see how i go
didnt understand/find the 2nd setting though
cheers
dan
hi dan - i didnt try yahoo app as it got some bad reviews saying it needed fixing etc :/
cheers
dan
The yahoo mail app isn't that bad and I find is much better to use as opposed to fiddling around on the html site. Main gripe with it that they still haven't seemed to have fixed is that you cannot click on any links included in a message. You have to copy/paste. Many have complained but they haven't sorted it with the past couple updates.
Give it a go anyway. You can always uninstall!
am really liking yahoo mail - v good
also like the notification pull down bar thingy - that works well
cheers
dan
+1 for dolphin too.
Thing is with Android compared to iOS you have to set more up out of the box but it's ultimately a better and more personal experience. Can understand your initial panic but trust me it'll be all good :D
You now have the phone of the year and not just the runner up!
:D
thanks guys - yes i was flapping some wasnt i :D
think i might have sorted my internet issue - fingers crossed - seems could be my old sim - was 3g, but poss not hspa/da/dpa or what ever it is called :)
cheers
dan
