Like the the post says my wireless tether no longer works( at leat not fast ) with any of my 2.2 nandroid backup I have all the wireless thether downloads ( the 2.0.2 and all the 2.0.5 versions ) and they just stoped transfering or transfer really slow. By slow I mean it will take anywhere from 30 seconds to a minute sometimes longer for a page to load. This is the case with all my 2.2 roms Damage Control 3.5, Baked Snack 1.0 and 1.5, Fresh 3.something and even my stock 2.2 rooted rom. This is the case with any kernel and I have been using various Kings, (but tend to stick with Netarchy's kernels) All with the same problem. Everything else works flawlessly.
This wouldnt be a big deal except I use wireless tether everyday for homework so it is a must have for me. I had to use the tether feature on my wifes Palm Pre (you know how that made me feel
) I have her phone overclocked to 800mhz and it felt as if her battery was going to melt or explode, which usuall happens if you use it for too long. I had to get an Ice pack and put a towel on it to keep the phone cool while tethering.
I even tried it with flashing new room and kernel and the only app being all the versions of the wireless tether. That still was a no/go.
I however did find a solution but not a good one. I had a nandroid back up of a HTC 2.1 stock rooted rom with Nand unlocked and with the FPS un capped. This however when I look for wireless networks to connect to on my computer, it shows up as 3computer connected together instead of the 5 escalating bars like in the att comercials (dont ban me for that)
but it works perfectly and lightning fast. The version I'm usuing is the 2.0.2 version not any of the 2.0.5 versions.
I know this is a bit drawn out but can anyone explain why this happened? I mean it worked one night and the next it didnt. Or can someone can someone explain why it works on 2.1 and not on 2.2?
I miss some of my 2.2 feature but there are none that I can't live without but I would like to be on the latest software version so can anyone help me with my issue?
![Eek! :eek: :eek:](/styles/smilies/google/eek.png)
