chicomostoc
berore.... battery lasted me more with ZVB .... I will return to ZVB .. but I've never tried zvc
which is better for you ZVB or ZVD?????
man ZVD is better than zvb and if you do downgrade don't put zvc
Wat up broman ZVD is better than zvb and if you do downgrade don't put zvc
chicomostoc said:Why not zvc?
Go ahead you'll be back on zvd![]()
Im zvb right now and my battery last easily two days without charge ofcourse i have extended battery but hey if aint broke dont fix it right?
Probably a noob question but I'm on #2 and it shows zvc... Lol
before u do, have u tried 2.2 w Kanaiya homeless?
yes i try it with the homeless kernel on ZVD .. but sometimes the phone freezes ..
before I was homeless kernel on ZVB. and never had problems
Homeless is for ZVB only. Or so I thought.
correct, and if flash on zvd you will bootloop. :smokingsomb:
Most ROMs are interchangeable between all the versions. But no one actually knows whats going on so it's best to just keep it kosher.
Shiny and I ran B plague on D for a while but this was before #2 became what it is now.![]()
