Root Icarcus or CM6/CM7 Mod???
I'm thinking about switching and i was wondering which one is the best? I really only want the phone to be faster, but more customizable settings and other things like that would be cool, too.
I'm probably going to get my friend who is good with tech to do the mod for me, however, if it is really easy, i might just do it myself.
I want to know which is the best/fastest/smoothest. But i also need one that has the same same functionality as the stock phone (like pic messaging, wifi, mms and other things like that)
and are there any other good mods i need to know about? i apreciate all replies. Thanks!
There are all good, but cm6 n cm7 dont have mms working yet. Cm7 has minor bugs here n there.
Icarus has everything working I do believe but its still 2.1 just cleaned up.
Personally I like CM7 :)
What he said...but i prefer CM6. Flashing the roms are quite simple if you just take your time and read carefully and don't deviate from the directions. Once you learn how to flash one, you can flash them all to find the one that you like.
Since you want mms you want to use Icarus for now. It is a cleaned up and streamlined version of the stock rom.
i would recommend cm6 or cm7 if you dont mind not having mms....it more smoother and also it's OC to 710 and icarus is OC to 600, but all roms are fast and smooth.
