Root ICS ROM themes?
jtragna
Member
Hi, i have the Ice Cream Sandwich ROM by Thaunknownartist. I was wondering if i can use themes with it...the ROM came with an app called Theme Chooser. I downloaded ADW themes (thinking those would work) and they dont They dont show up. I was also wondering if BACKside ROM themes (ex. Green Machine) would work with it. Thanks!
The theme Chooser app is for "cm7 themes" on the market. (You install from the market, and use theme Chooser to apply the theme.) Themes such as green machine, or any other themes that are. Zip files, are flashable themes, in other words, you cannot undo them, unless you do a fresh install of the rom.
That rom is a themed version of backside so it would be better to get the original then theme it that way you have all the updates and all the themes we create.
Flashable themes need to be built for each specific rom, you can't mix and match. ADW themes have to be set in the settings for ADW itself.
I flashed the newer or more recent version of the same ICS themed cyanogenmod (i thought it was the same) but it seems different than before. Possibly more stable, but some things changed like I have a green status bar instead of blue and stuff like that, but anyway, below the regular status bar there seems to be a row of black with a battery indicator (in blue) that I think I had before but removed it somehow. Any ideas on where to go in settings to remove this?
Edit: the theme of TheUnknownArtist
