I downloaded the ics themes for mik 2.61 and tried them both out not really knowing the difference between the two. Regardless, the same problem happens with both of them. I do a full wipe, factory reset, superwipe, all that. Reflash 2.61, then flash the theme. Both versions get stuck at what I'm guessing is the boot animation. A bunch of multi colored squares rotating and moving around. I let it go for a while thinking it needed time to boot up but it went on for 20 minutes or so. Had to pull the battery to restart. Also, the boot animation ate up about 50% of my total battery life. Ugh... anyone else see this before?
