Root Idiots Guide To Rooting Kindle Fire HD 7" 7.2.3
Original post edited to include the installation and use of the Android SDK if required
One small correction that will fail if not done right. In that section you have
"Now open RunMe.bat as administrator and see if that works"
Yes, and no. You need to not right click it to open cmd, it will not work that way.
Open cmd from the start menu, navigate to the folder, then run it.
I got a new Kindle Fire HD 7.2.3 for Christmas right?
Well, I followed these instructions down to code and it rooted my kindle. Problem is. Screens gone black, nothing will show up and everything is lagging! is their anyways to undo this? I tried unroot but it wouldn't work....
NVM. If anyone runs across my error just redo the steps again, it will work and give you super user. I suppose sometimes you've got to run the program twice or more to work it.
Thanks Inksaver :D
Ok, Well when I go to the googleplay app it tells me to input my google account. I do so, then it says "Can't establish a reliable data connection to the server. _______________________
This could be a temporary problem or your phone may not be provisioned for data services. If it continues, call customer care."
It's not a phone.. It's a kindle fire HD connected to wifi. Pretty high quality wifi as well.
u asked how i improvised .. . .... i simply restored my device to factory settings, downloaded java on my pc and reinstalled the adb drivers .. . ...this time i after installing the drivers i did not get a message saying 'drivers nit installed properly please install manually ' it went smoothly ... i also found out how to get go launcher ex working in my kindle fire hd
@Rollout
Thanks for the Heads-Up. Original post edited to relect this I am wondering whether as the SDK is not "Installed" in true windows fashion, i.e. new .dll files added to System32 and registered with regsvr32, and no additional registry changes, it would be easier to simply copy the platform-tools folder into C:\, rename it as "root", add bin4ry's tool, modify RunMe.bat and proceed.
If this did not tread on any copyright/licencing etc. issues then this could be made available as a pre-modified tool of 33MB size to be attached here?
@Delusionalhelp
It is important to install GooglePlay in a two step process.
On your Kindle Tap apps on the text menu home screen
Long Press Google Play Store and "Remove From Device"
Now re-install "Market" following the guide Section 4, and sign-in first!
Only if that works is it safe to over-write with GooglePlay
@xeth
It looks like you have the same problems as Rollout from post#8 onwards. The guide has been modified with his help to get over this situation. There is now a new Section 3.5 - "Permission Denied" and other errors during Root process. Please give it a try and let us know how you get on.
@timaestro
Did you use the Jave JRE (Runtime Environment) or the full development kit?
Sidenote: Please be careful putting your email on a forum. Spambots love it. Either request using PM (Private Messaging) or diguise the address e.g. MyName[AT]MyDomain[DOT]com
This was awesome. I couldn't get anything else to work. Thanks for taking the time to give a step by step for the not so tech savvy people.
By far the best set of directions I have seen, thank you for taking the time to do it.
I do have a question. I am still getting permission errors in both the runme.bat, and the rootqemu. It says permission denied to creating any of the files/folders, such as coping stuff/su over to /data/local/tmp/./su also when coping superuser.
any ideas? Been at this for a while
edit: I am using win7 , and using admin for my cmd console. It is not working...
one example, /system/bin/sh: cannot create /data/local.prop: Permission denied.
It does find it and give me shell access in adb though.
i used alternate usb drivers to get rooted. had same issues. my KFHD popped up screen regarding usb drivers. after installing amazon adb drivers, went back in devices and updated with usb driver. everything worked after that. spent probably 12 hours over several days pulling hair out, but got rooted on last attempt. hope this helps. using win 7 ultimate 64 bit.
Thanks for this thread. used same methods, but under some other forums. this is by far the best explaination i have read or followed. wish i had discovered earlier. thanks again for sharing your knowledge.
Thanks for the guide!
Now for my problem. I have Windows XP. Is there ANY WAY to do this with Windows XP????? If not I'm pretty screwed :(
Also, is there a way to side load my apps that I've paid for in the Play Site without using Appmonster? I'm rooted on my current android device, where do I navigate to in the file explorer (I use Root Explorer) to find the . apk?
I have had a play with an old Netbook with Windows XP. It looks like you can still do it, but you need to Install the 32bit version of the SDK first as Section 3.5 above, run Eclipse, then plug in your Kindle. After a while Device Manager shows Kindle>-adb composite device, but the MTP device has a yellow warning triangle.
You will not see the Kindle as a removeable drive, but the adb.exe found in Bin4ry's rooting tool will discover it after you add the adb_usb.ini file and typing adb devices in a command prompt will give you access to the device.
I will add an update to the original post later, but carry out the steps above allowing for the differences in Users / Documents and Settings etc. between Win7 and XP.
If you look in \system\app on your rooted device you should find the .apk's there and copy them over. Any paid apps would need you to be signed in to your GooglePlay account in order to verify you are licenced to use them, otherwise they may not run.
Thanks, Inksaver, for an excellent tutorial, the best I've seen. Few have the ability to write -leaving nothing out- in a way that noobs can follow.
Anyway, I tried out a couple of other "methods" I found on other forums, and couldn't get past the "permission denied" problem(s).
I encountered only a couple of problems using your instructions, but found clues after reading the forum replies:
1) After the reboot following running RunMe.bat, my kindle was extremely slow and wouldn't even finish drawing the screens, just as Delusionalhelp described in post #27. After reading his post, I ran the RunMe.bat again and rebooted again, and voila, it came up working like a charm.
2) Also I found that I couldn't reach the google server to log in, again just as Delusionalhelp described in post #28. After a half dozen tries, I finally logged in successfully, and then proceeded with installation of google play.
I also got rid of the lock screen ads, and (hopefully) prevented automatic OTA (over-the-air) Kindle firmware updates by installing and using DroidWall's blacklist. Time will tell.
Kindle Fire HD 7' version 7.2.3 out of the box.
Registered just to say thanks.
Thanks for giving your feedback. I can now emphasise the two issues you mention by editing the original post.
This reply has been typed in Chrome browser on my Kindle fire which I installed a couple of minutes ago from apktop.com after GooglePlaystore informed me it is not compatible!
First off, Thank you Inksaver for such a great guide! I followed all of your directions precisely and everything has been great.....except, I'm having the same problem that Delusionalhelp had as far as trying to sign in to the "Market". I installed the market in two steps just as you instructed, but when I try to sign on and still keeps giving me the "Can't establish a reliable data connection to the server. _______________________
This could be a temporary problem or your phone may not be provisioned for data services. If it continues, call customer care." message. I tried to just keep signing in, but it stills keep giving me this message :( Please help
@killakey
Not too sure about this one, but give this a try:
Settings (More...)>-Wireless>-WiFi
Tap the connection you are currently on>- Forget
Re-Boot
Settings (More...)>-Wireless>-WiFi>- Add Network
Re-Establish a connection to your WiFi
Try Market again
I have found this to work on phones before.
Hi Inksaver
I tried what you suggested and it worked like a charm :) Thank you again for all of your help :) I'm so excited to use my Kindle now!
Okay I've got all the files downloaded, and in the right folders. I have the adb_usb.ini file renamed to just that, but there was no warning of any kind about the file type. I go through the Command Prompt and it shows nothing for Connected Devices. I ran it anyway, and it sits there after I select Normal. Nothing further. If ANYONE can help, I'd appreciate it. Thanks!
Running on 7.2.3 as this guide says it is for.
Further explanation as to where I am:
I don't get anything after I type "adb devices" and press Enter. This, I do NOT get:
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
D025A0A024360KLP device
Im having an issue installing the google app store, I got the kindle rooted and when i go to root settings and check the root explorer box i get the warning "When SU request dialog popup, please select always allow or make system remember your allow choice. I hit yes then i get "sorry, test failed. This feature cannot run on your phone". Anyone encounter this problem? I tried re-rooting the kindle and i got the same message again.
@ JMPunk883
Looks like your Kindle is not recognised by your PC
Check:
1) Device Manager on your PC for:
a) Portable devices - click on it to reveal "Kindle Fire" (Windows 7 only)
b) Kindle Fire - click on it to reveal "android composite ADB Interface"
2) Ensure your Kindle is set up to allow USB debugging:
a) Set "Allow Installation of Applications" to On
b) Set "Enable ADB" to On
@ thexfactord22
If you are rooted, then you should have SuperSu listed in your apps list
Tap to start it then go to Settings on the menu bar (apps|Logs|Settings)
Ensure Enable Superuser is ticked
@ JMPunk883
@ thexfactord22
I dont see it on my app list, does that mean im not rooted? I followed the instructions and wen through all the reboot and start up everything happened like you described, even said i was rooted at the end so i dont know what i did wrong....
Thank you very much, Inksaver!
This is the first guide that actually works :P
I might add that signing in with Google only worked for me after a restart (not just after half a dozen tries ^^)
@thexfactord22
Looks like you are definitely not rooted.
Maybe do a Factory Reset and try again?
If that still does not work, and you used the simpler method (without installing the Android SDK) it might be worth trying the SDK (use Section 3.5)
